Dave's Orange Betty EK Sedan
I would be more inclined to replace the entire turret than try to weld that patch in , that looks like warp city to me, way beyond my capabilities ...... :shock: :shock:
Orange Betty
Post by Orange Betty »
Warpage is what I'm worried about Blacky.
Do you mean replace the entire panel between the end and middle support?
Dave
62 EK Sedan in slow progress
I think the more common approach is to uncouple whole roof at gutter and windscreen spot welds Dave and replace. I'm just checking with a mate if he has one😀
Orange Betty wrote: Wed Oct 13, 2021 7:55 am Warpage is what I'm worried about Blacky.
Dave
I mean chop it through the A, B, and C pillars and replace the lot - make a frame that fits your front and rear windscreen gaps, brace the body and chop away - fit your seat belt plates while it’s off too 👍
Blacky wrote: Wed Oct 13, 2021 9:35 am I mean chop it through the A, B, and C pillars and replace the lot - make a frame that fits your front and rear windscreen gaps, brace the body and chop away - fit your seat belt plates while it’s off too
... and skim 4" or so off those A/B/C pillars while they are exposed :mrgreen:
Orange Betty
Harv wrote: Wed Oct 13, 2021 11:25 am
Ha, ha, well Ian Rousell from Full Custom Garage makes a chop look easy - but maybe a sunroof install in the rear section is the solution :wink34:
Dave
Do you know someone skilled with an English Wheel Dave? If you can cut out the section to be fabricated and take it to an expert metal worker it would be a good start. The welding bit is well within your skill set.
Orange Betty
Ok, young Brett convinced me to rethink my roof strategy and put me onto the bookFace forum for FB/EK parts which rather promptly turned up a few roof cut options. So after a rather wet trip out to Junee yesterday (3hrs each way) I have this:
Roof cut1.jpg (138.76 KiB) Viewed 3454 times
Roof cut2.jpg (145.24 KiB) Viewed 3454 times
Roof cut3.jpg (111.9 KiB) Viewed 3454 times
The gentleman I bought it from had a few FB wrecks in the yard an FB sedan and wagon under construction in the shed and a very nice and completed wagon with a 3 inch roof chop! I'll stay stock with mine once I figure out what to do next.
Dave
I like the idea of young Brett, but sadly now only in comparison to dinosaurs.
Well done. Dave. Pity about the GT stripe down the middle, but it looks good and solid enough. Look forward to seeing how you use it.
As soon as you mention FB's and Junee everyone knows its gotta be Mark Oriel - th ebuild of his wagon is well documented on here, it was chopped by Ed Ho in Sydney, finished in Wonthaggi by Trev and now in Marks custody :thumbsup:
Good score Dave. So that’s where Trev’s wagon went.
Orange Betty
Blacky wrote: Sun Nov 21, 2021 11:12 pm As soon as you mention FB's and Junee everyone knows its gotta be Mark Oriel - th ebuild of his wagon is well documented on here, it was chopped by Ed Ho in Sydney, finished in Wonthaggi by Trev and now in Marks custody :thumbsup:
Yep, that's him. I'll have to read his build story. Never paid much attention to wagons but now having been up close to one they are pretty cool!
Dave
Orange Betty
New old roof!
New Roof.jpg (99.08 KiB) Viewed 3385 times
Well almost, it is just sitting there over the current one. After lots of procrastination I just bit the bullet and cut the skin off the donor. And this is what the roof structure looks like underneath
Roof structure.jpg (55.68 KiB) Viewed 3385 times
Well I'd never seen one before. Will have to utilise all/some of the rear support as mine is much worserer
Rear support.jpg (74.12 KiB) Viewed 3385 times
Also saved 3 large black Tumut spiders that were living in the donor roof.
Dave
Looks like you are on top of it all, as usual Dave. Best option taken methinks😀
Jeez mate you are in deep now
