Holden Diff Ratios
Wrongway Roger
Re: Holden Diff Ratios
Post by Wrongway Roger »
Ratio marked on the crown wheel.
FbSTDwagon
Post by FbSTDwagon »
Thanks Rodger, I’ll do some investigation.
I have a couple of ate fb diffs but I’ll be on the chase for a 3.36 for my wagon.
Thanks again
Drew
Often stamped on the pinion oil singer as well drew. That is the pressed metal ring sits over the seal. 1:3.89 ratio are the only type that have the old style pinion flange that accepts bolt on uni joint caps. 3.08 and 2.78 ratios have a slightly different casting which requires a longer stud in the axle housing, and from memory also a long drain bolt. As above, you can verify the ratio installed by jacking up one wheel, rotating through two revolutions and counting tailshaft revolutions. Or rotate both wheels by 360deg.
FbSTDwagon
Cheers Clay, that info about the bolt on Uni saves me dismantling to look for markings.
I’ll go have an eye ball at what I have got in the yard!
Drew
FbSTDwagon
Looks like I have 2 centres both at 3.55.
Better than the factory 3.89 I guess!
Both very rusty and in need of rebuilds though
Drew
FbSTDwagon
Stupid question and I’m sure they are the same but I need to ask…
Sedan and wagon diff housings are the same?
Drew
Yep. Sedan and wagon diff housings are the same.
If you're after diff centres, it'd be worth getting in touch with Simon at HKTG Parts Recovery.
Same same same
Minor differences through the models. FB EK got a different axle bearing and (no) seal arrangement to FE FC, as well as wider springs and brakes. EJ got new brakes with different axle housing flange to bolt up the different backing plates, and went back to the FC style bearing and seal set up.
basic.green
Post by basic.green »
hi mate i am at andrews farm s.a and have a 3.36 $80 bucks if any good to ya
building the dream Rick
FbSTDwagon
basic.green wrote: Thu Sep 02, 2021 2:28 pm hi mate i am at andrews farm s.a and have a 3.36 $80 bucks if any good to ya
Christ mate how can I say no to that!
I’ll message you my number
Shout out if the message doesn’t come thru, I’ve had a few messages go no where lately.
Drew
Hey Drew
I am thinking that 3.55 might be a good addition to my Ute which I presume has the original 3.89 diff??? Would be interested in having a look one day if your not in a hurry to dispose of it. Thanks
FbSTDwagon
In the Shed wrote: Fri Sep 03, 2021 9:51 am Hey Drew
Yeah mate that should be no problems, I’ll just get my wagon sorted out first as I’m not sure exactly what will be needed.
And both of the 3.55 centres have been exposed to the weather for many years too so only a clean up and inspection after the acid bath will truly tell what they are like
Drew
FbSTDwagon
Hey bud the Pm I sent you is still in my outbox, drop me a cal or message on 0433134260
Drew
FbSTDwagon wrote: Fri Sep 03, 2021 1:50 pm
Thanks Drew
