Replacement Headlight Switch
Re: Replacement Headlight Switch
Greg, waiting on your address and surname and I will get them in the post.
Switches were posted yesterday lads, sent you all a PM with the damage - bank details are on this thread a few posts back.
Absolute legend Blacky
Switches arrived. Look the goods.
Thanks Blacky,
Picked up my switch today and it looks a great re production.
I fitted one to my ute on Monday night , works a treat :thumbsup: :thumbsup:
Thanks heaps Blacky. Mine turned up today. Looks perfect.
FbSTDwagon
Post by FbSTDwagon »
Hey guys just about to pull the trigger on a HR headlight switch from Rares to fit into my wagon.
Does the FB knob & shaft fit into a HR switch ?
Same for the mounting nut and plastic bezel surround?
Cheers Drew
Drew
Drew , that looks more like a HQ style that has the triangular shaft ? Have you had a good look at it ??? Do Rares not have the FB/EK style in stock ?
FbSTDwagon
They do buts they are like $170 which I’m avoiding.
I have a fb switch but was looking to retro fit something a bit cheaper and easier to source
Drew
We did a bulk buy from the US and bought 6 from memory, might be time to do it again, they ended up at around $90 as I recall
Just bought 3 more as I need one fo rthe rattler- exchange rate not so good - a poofteenth under $95 each
Just got back to work after wasting a week of my life at Tanami minesite being screwed around by engineers who don’t know how to use a tape measure :evil: :evil: :evil: and on my desk are some presents :D
I bought 3 more of the same ones we bought last time plus a generic type that was only $57 delivered that looked similar-
The generic one will do the job, is physically smaller and has a circuit breaker rather than a bi metal switch, when I get home I will see if the park light circuit operates as per a standard FB/EK or if it’s on when the headlights are on as well - the biggest drama for a direct replacement is you can’t use a stock headlight knob in this switch.
Not a biggie if you were using custom switch knobs but no good for a resto
I see that the repro one has 12V stencilled on it. The ones I got from you last time have 6V on them. Still work good and I’m sure it isn’t an issue.
Errol62 wrote: Tue Feb 28, 2023 9:18 pm I see that the repro one has 12V stencilled on it. The ones I got from you last time have 6V on them. Still work good and I’m sure it isn’t an issue.
The 6V ones if anything would have a higher current rating seeing as I(current) = E(voltage) / R (resistance)
