LS1EK
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Tank all tacked up, just need to repair my GTAW and I will weld it up. After welding will add the mounts and filler neck.ImageImage
Re: LS1EK
Thanks for the update taz. Very impressive work as ever.
Re: LS1EK
GTAW ??? :econfused:
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Blacky wrote: Tue Dec 22, 2020 10:48 am GTAW ??? :econfused:
Gas Tungsten Arc Welding, sorry I forgot there were sparked on this page 😁😁
Re: LS1EK
Nice work TAZ.
You have great fabrication skills and that tank is a beauty !!
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
EK283 wrote:Nice work TAZ.
Very kind words there cobber. Managed to run some welds around the tank.
Next step is to fabricate some mounts and look at a filler.ImageImageImage
Re: LS1EK
TAZ wrote: Tue Dec 22, 2020 11:08 am
TIG :lol:
Very neat job sir.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Tank now mounted. Once painted black it should blend in well.ImageImageImage
BILLY BLACKARROW
Re: LS1EK
Post by BILLY BLACKARROW »
looks like you intend to have some big rubber on the back :evilll: :evilll: how big
BILLY BLACKARROW
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
BILLY BLACKARROW wrote: Thu Dec 24, 2020 5:02 pm looks like you intend to have some big rubber on the back :evilll: :evilll: how big
Should get a 12 inch tyre under there if allowed to.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
So back on the centre console today.
Fiitted the mounts and opened up the hole around the hand brake so that I can actually fit the hand brake once the console is installed. Will have a boot made up to cover the hole.
Also cut the holes for the cup / stubbies holders.
Once this was done I made a start on the cover panel for the passanger side.ImageImage
gpi
Re: LS1EK
Post by gpi »
is that going to be metal too? or are you going to upholster it?
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
gpi wrote: Wed Dec 30, 2020 4:32 pm is that going to be metal too? or are you going to upholster it?
Will be either painted or covered.
59wagon
Re: LS1EK
Post by 59wagon »
That console looks the ducks nuts Taz. You do great tin work.
Cheers, John
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Bit more done today. Drivers side panel made but need to weld on some sections around the column to fill in the gap.ImageImage
