So you want to run Amals on a grey? Hopefully the information below helps you to get there. I am going to draw from a heap of information that is available online, but also from the book Super-Tuning Amal Monobloc, Jeffrey Diamond, Victory Library (
http://victorylibrary.com/brit.htm). Jeffrey’s book is damn good – lots of technical info and practical hints. I’m not going to upload it here (as it is copyrighted), but will draw info from it as I go. If you want to play with Monoblocs, this booklet is worth buying (his booklet on Concentrics is similarly good value).
There are various types of Amals, but I am going to focus solely on the Monoblocs. Amal made a few different types of carb, but the two most common are the Monobloc (which has an integral float chamber off to one side) and the Concentric (where the float chamber is under the carb). The Monobloc was available from 1955, and hence was around for the grey motor’s hey-day. The Concentric didn’t appear until 1967. I’ve seen a few Concentrics on grey motors, but realistically by the late 60’s/early 70’s the grey had been ousted by the red motor. There are some pre-Monobloc Amals that could do the job, and some fancier Amals (the GP and TT carbs) that were probably only available to blokes with a bigger budget. The Monobloc feels more period correct though – right era, and readily available to the general enthusiast.
So you bought some greasy, dirty carbs off eBay… just what are they?
Monoblocks came in four series: 363, 375, 376 and 389 series. The easiest way to tell which series carb you have is to check the specification number stamped onto the manifold flange, as per the red circle in the photo below:
- Specification number.jpg (544.92 KiB) Viewed 2495 times
The stamped number will start the series, followed by a few numbers (e.g. 376/303). You can then use the online Amal catalogue (
https://issuu.com/burlenltd/docs/amal_catalogue_2013-8) to find more information on your carb.
Each series also came in a variety of bore diameters:
363: 0.475", 5/8", 11/16", 25/32" and 13/16".
375: 21/32”, 23/32”, 25/32”, 13/16” and 7/8”.
376: 15/16”, 1” and 1 1/16”.
389: 1 3/32”, 1 1/8”, 1 5/32” and 1 3/16”.
It can be difficult to measure the bore size, so the easiest way to confirm is to strip the carb down and read the numbers cast into the jet block. These are the bore size, in the nearest 1/1000”, For example in the photo below, the number cast in is 1.062 (11/16”).
- jet block casting.jpg (1.55 MiB) Viewed 2495 times
The bore size should line up to the info in the Amal catalogue too.
Now that you know what carbs you have, it’s time to pull them down. The Amals are pretty simple to strip down, with no fancy tools required and no special clips that go sprong! and fly across the shed at the speed of light. Take your time, and it should all unscrew. I found that the main body/tower bore can be manky with coke, and sometimes the throttle valve and jet block need some gentle persuasion to get them to come out. Go easy… this is all zinc alloy, and will bruise easily if you are heavy handed with a BFH. Once apart,give everything a birthday with some petrol and a toothbrush. Go easy with the probing tools… no oxy jet tip cleaners. There are a few very fine tolerance holes and machined surfaces that need gentle love, not flogging out until brass shavings appear.
Once everything is clean, there are five tuning parts to check to make sure are the same across all your carbs. These are the bits that could have been swapped out by a previous owner. The photo below (from left to right) shows the jet needle, the main jet, the needle jet and the pilot jet.
- needle and jets.jpg (1.63 MiB) Viewed 2495 times
The red circles in the photo show where numbers should be stamped into the parts. The numbers can be really hard to read though.
The photo below shows the throttle valve. Cast into the top of the throttle valve is the series number, followed by cutaway number. In the photo below the number is 376/3½.
- throttle valve casting.jpg (1.58 MiB) Viewed 2495 times
The options on the tuneable parts are as per below:
jet needle: one needle only for 363, B for 375, C, C1 and C2 for 376, D and D2 for 389.
main jet: 55-150 in increments of 5, 160-600 in increments of 10.
needle jet: 105, 106, 1065 and 107.
pilot jet: 20, 25, 30, 35, 40, 45 and 50.
throttle valve: 2, 2½, 3, 3½, 4, 4½ and 5.
More to follow.
