Gimme 5 years
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Hi Rob,
I suppose they are more of a cutter than a drill really - yeah, got them from Sydney or Total most likely ... 10 double sided ones for about $40 - they seem to last pretty well
https://sydneytools.com.au/product/dayt ... ll-bit-set
I'll see how I go with getting EK wheels before I let the others go. The one I painted was in good condition, I haven't had a good look at the other HR one yet... will keep you in mind.
Patrick
gpi
Re: Gimme 5 years
Post by gpi »
youd do well to find 2 more of the hr ones with the hole and flog the standard ones to fund their purchase Patrick
Re: Gimme 5 years
Got some here just need the hole drilled. ;o)
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
gpi wrote: Thu May 14, 2020 7:57 pm youd do well to find 2 more of the hr ones with the hole and flog the standard ones to fund their purchase Patrick
Are they a better wheel?
What about widths? what is a standard EK wheel width (book says 4.5 in but then I see similar looking wheels advertised as 6 in)
Are HR rims wider? (hard to measure the rims with tyres on)
Patrick
Re: Gimme 5 years
Geez Patrick
You didn't mess around with that patch panel ......... your making good progress on little jobs here and there. Good stuff :thumbsup:
Re: Gimme 5 years
FE through to HR were all 4.5x13”. HD got wider brake drums, necessitating a change to the wheel centre profile, so you can’t fit the FE to EH rims on HD HR brakes. No problem fitting the later wheels to earlier cars, except that the ones with the holes have 1/4” wider rim offset. These were fitted to HR sedan and wagon.
All the later wheels will fit the disc brake front hubs available on HD HR. These are often retrofitted to the earlier cars.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
thanks Stephen,
yeah, I thought I was finished until Spring; but, there's a couple of hours in the middle of the day that are okay for now...so good for the smaller jobs.
While I was banging around at the back, I found another 'non-original' bit
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Errol62 wrote: Thu May 14, 2020 10:47 pm FE through to HR were all 4.5x13”. HD got wider brake drums, necessitating a change to the wheel centre profile, so you can’t fit the FE to EH rims on HD HR brakes. No problem fitting the later wheels to earlier cars, except that the ones with the holes have 1/4” wider rim offset. These were fitted to HR sedan and wagon.
thanks Clay
Re: Gimme 5 years
You found another standard rust spot for utes and vans Patrick. Ah, the memories. That was the only place on my ute that had bog and it still took me two plus years to fix the rust.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
Errol62 wrote: Thu May 14, 2020 11:45 pm You found another standard rust spot for utes and vans Patrick. Ah, the memories. That was the only place on my ute that had bog and it still took me two plus years to fix the rust.
yeah, could do with a drain hole ... both sides were rusty and both inner and outer needed patches welded in - anyway, that's another couple of bits sealed up before winter
rear 1.jpg (78.72 KiB) Viewed 567 times
rear 2.jpg (64.38 KiB) Viewed 567 times
rear 3.jpg (62.42 KiB) Viewed 567 times
Re: Gimme 5 years
There was a drain hole in the design but may not have progressed on the factory floor. A lot of unskilled labour back then and drain holes often got spot welded shut.
62ekute
State: ACT
Re: Gimme 5 years
Post by 62ekute »
FJWALLY wrote: Mon May 04, 2020 8:17 pm what are the screws holding or are they just filling holes?
just a piece of stiff material to block off the hole
had a bit more of a look at the 'patch' today, the two screws were holding:
a strip of aluminium,
a piece of sandpaper, and
a folded envelope
shelf 1.jpg (67.89 KiB) Viewed 550 times
shelf 2.jpg (85.25 KiB) Viewed 550 times
Re: Gimme 5 years
yep, thats how you do it .......... :roll: :roll:
Re: Gimme 5 years
That is nearly as curious as how the hole got there in the first place.
FJWALLY
Gimme 5 years
Post by FJWALLY »
Thats gold - at least he took the time to make a gasket - love finding those old bits of paper though - often tell a story all their own
