Neils Frankenstein Ute
FJWALLY
Re: Neils Frankenstein Ute
Post by FJWALLY »
perfect - attach the standard winder and it would look mint.
Got back early from the job offshore so had the weekend in the workshop, finally got both electric windows working properly so fitted the wiring and connected to Frank's battery just waiting for door cards to come back from trimmers (with the bench seat) so I can fit the switches.
Also finished the sound proofing.
Need to order carpet when I get back from the next job and still trying to finish tidying the wiring.
Not much more to do to finish just work getting in the way :roll: :roll:
Progress
Ordered carpet the other day from Knox carpets on eBay.
Also Drew the trimmer sent me a couple of photos of my bench seat and door trim will pick them up later next week.
I'm waaay too grotty to ever own white trim, but those door cards look stunning. Very neat job :thumbsup:
WesternWagon
Post by WesternWagon »
Trim looks great, some tidy stitches there
Can’t wait to see her on the rd mate
Gazza
Member : Holden Car Club WA.
:ASRF Member
59wagon
Post by 59wagon »
Looks schmicko Neil
So you didn’t need a cutout for the gearstick - cool.
Cheers, John
Very nice Neil. Love the yellow piping. Don’t forget to take the scanners out of the back pocket of your greasy overalls before you get in the car mate.
CHOPPED
Post by CHOPPED »
im looking forward to seeing this on the road for the dunn runn mate
THIS YEAR :lol: :lol:
HEY IT WASNT ME
Will look awesome Neil :thumbsup:
FJWALLY
Post by FJWALLY »
Trim looks Awesome Neil - can't wait to see it in the truck
My brake pedal does not drop very much with the engine running and is pretty hard I am assuming it is loss of vacuum due to the cam in the little V6 :wtf:
Can anybody throw a little light on this I'm thinking I may need to measure the vacuum at the hose to the booster and if it is low say below 14" of vacuum or may have to fit a vacuum cannister; I'm open to other ideas guys :roll: if I have good vacuum then maybe my flash shiny booster is cactus, I remember reading somewhere that they are not that flash from eBay :x :x
Just received my carpet and picking up bench seat and door cards tomorrow
Hi Neil,
Usually if you put your foot on the pedal then start it the pedal should drop, this quick test indicates the booster is ok.
Not sure what vacuum you need but Harv went through this not long ago.
Engine on and pedal drop = OK booster.
Engine on and idle increases with brake = torn diaphragm.
Rough guide: 16-14mmHg at idle needs a vacuum tank. Less than 14mmHg needs an electric pump and tank.
For mine, The You-and-I VH151 vacuum brake booster is of very small volume (1.4L). When combined with the engine’s low vacuum (13”Hg at idle), the resultant vacuum power is very low, causing hard brake pedal after a few brake applications. To resolve this, I’m using a Protek VT1 vacuum tank (3.1L). The vacuum tank is coupled to an Aeroflow AF49-150 electric twin piston vacuum pump, controlled by a Hobbs switch. There is a bloke selling the same kit on Ozrodders - grab it for a good deal.
Harv,
Off-topic, but -
Vacuum tank + electric vacuum pump + low-vacuum switch sounds like a cure for lazy vacuum wipers. This will be worth looking into.
