Ute tub rubbers.
oz_ek
Ute tub rubbers.
Post by oz_ek »
Anyone know if there's a replacement rubber available for the area indicated by the arrows?
Thanks, Phil.
Re: Ute tub rubbers.
theres a rubber in there ? I thought it was just seam sealer type goo ??
Apart from wiring grommet and drain tube under the tail lights I thought so too
vmx-mxr
Post by vmx-mxr »
I'll try and see what the old FB has in it ...
oz_ek
Post by oz_ek »
Blacky wrote: Thu Dec 28, 2017 10:31 am theres a rubber in there ? I thought it was just seam sealer type goo ??
Thanks for the replies guys!.....Its been so-long since I pulled whatever was in there out (22 years) I couldn't remember.
feute
Post by feute »
Phil heres what it looks like from factory
FE Ute 1.JPG (349.97 KiB) Viewed 1436 times
oz_ek
Post by oz_ek »
feute wrote: Thu Dec 28, 2017 8:36 pm Phil heres what it looks like from factory
Thanks for the pic FE. :thumbsup:
Old Holden
Post by Old Holden »
Hi Phil
There is definitely a rubber under the sealer
Pic didn't work
Wayne
Gday phil
You sparked my curiosity with this so I tried to cut out a section of the rubber extrusion used to fill the gap between inner floor and rear quarter skin from rear of wheel well right around to tailgate jamb by the looks.
Hopefully the photos show the shape. I had to cut through the two tails that were sandwiched between the panels. I reckon it would be possible to source something generic to do the job. Failing that a liberal application of butyl mastic should do the job. Won’t be seen once the covers are on. ImageImage
oz_ek
Post by oz_ek »
Thank you Clay!.....I thought there was a rubber in there somewhere!... I vaguely remember pulling it out all those years ago.
Onya Clay,
Another myth busted! I wonder whether that rubber section is included when you buy a rubber kit?
Good excuse to indulge ones rubber fetish at Fitch the rubber man.
Cheers all
oz_ek
Post by oz_ek »
Old Holden wrote: Sat Dec 30, 2017 6:04 pm Hi Phil
Pic didn't work
Wayne
Sorry I didn't see this post, thanks for the input!
Hi OZ
Definitely a rubber there mate I had a look at my Ute this morning and you can clearly see it from underneath I will post a couple of photos on Tuesday when I'm back in the office.
Photos as promised
From underneath both sides
From inside the tray passenger side
