How To Glue Quarter Vent Seal (uprght channel)
Lex68
State: QLD
Post by Lex68 »
Hi Guys
Got all my bits and pieces to do door channels, weather strips, door seals, front and rear quarter windows, main door windows and mechanisms and all mouldings....
Quote from a previous post;
"The original rubber seal on the upright post for the quarter window was backed by a steel strip that had 'teeth' that clipped into the post. When I fitted new rares rubbers a couple of years ago I was told to remove the steel strip with 'teeth' and glue the new rubber straight to the upright post"
Ok...I've got the whole removal install thing with the quarter window and the C shaped seal. Its the upright channel seal that has me asking the question. The seal (rare spares seal vent front pillar 48 FJ FE FC FB EK 7408797) just does not look right and to simply glue it into the channel after removing the steel strip doesn't look correct. The seal is too narrow to fit into the channel? :eh: How is this accomplished with this rare spares part?
Re: HELP!! How To Glue Quarter Vent Seal (uprght channel)
Hi Lex
I too questioned the same thing about removing the steel strip with teeth. I've replaced 4 quarter window rubbers and in all cases removed the strip with the teeth. if you don't the rubber sit wont sit flat.
Have a look at page 38 on Old Timer thread http://www.fbekholden.com/forum/viewtop ... f=11&t=576
I used a Loctite glue. And the bonus is...no leaks. :thumbsup:
regards
Stewart
Lex68
State: QLD
Post by Lex68 »
Hi Stewart,
My quarter window vent seals were missing so I didn't have anything to go off except removing the metal strips.
So I've come up with this as the position the seal needs to be when glueing. Is this correct? :thumbsup:
I'll clean and paint before putting th seal in :wink:
steved57
Post by steved57 »
Lex, I just put mine in - but turned them over. So I guess one of us has 'em inside out! Cheers
Lex68
State: QLD
Post by Lex68 »
Steved57,
I haven't glued them yet...here is my interpretation of the installment;
The seal has a small c - channel profile that I have assumed allows for the 7 raised ' bumps" where the metal strip tabs originally sat.
The only flat side of the seal contacts up against the inner side wall of the upright channel, the small '45 degree' profile of the seal contacts against
and acts as the vertical seal for the quarter glass window when it is closed.
I could be completely wrong...I have nothing to go off, so, it's a logical guess :think:
Hopefully someone will confirm or set me straight!
Looks about right ??? seems like the only logical way it COULD go ???
Lex68
State: QLD
Post by Lex68 »
Blacky wrote:Looks about right ??? seems like the only logical way it COULD go ???
Yeh, I reckon thats it, :thumbsup:
Ditto what Blacky said. That's correct Lex.
Stewart
steved57
Post by steved57 »
Lex, your seals are a very different profile to mine - but have the same Rares part number. Got me beat!
Lex68
State: QLD
Post by Lex68 »
steved57 wrote:Lex, your seals are a very different profile to mine - but have the same Rares part number. Got me beat!
Mate pictures paint a thousand words.
if you are unsure, post photos of what you have, someone will respond, usually the same gurus.
For something that is not clear for whatever reason to one person is a no brainer to others for what other reasons.
Cheers :thumbsup:
mph
Post by mph »
Great post I had the exact same question.
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Re: How To Glue Quarter Vent Seal (uprght channel)
Ah ha! I knew I had read more on this (moron).
