W/Wiper arm spindle size
briby
Post by briby »
Been doing lots of searching but can't seem to find the answer, does anyone know the size of the wiper arm spindle?. Seems to be a few available from different company's in different sizes. Don't have a micrometer or vernier, but from my trusty tape measure i reckon 1/2", but the arm hole would be a good bit bigger than that at the moment. What do others do for worn out arm splines? Found these.
Wiper Arm Dimensions.docx
(92.37 KiB) Downloaded 159 times
FB Restomod V8 Sedan
rosco
Re: W/Wiper arm spindle size
Post by rosco »
Briby, can you give us a bit more on what you found.
I have a great set of replacement wiper arms for mine, but would like to know if you have found somewhere to purchase new replacements.
G'day Briby,
I too would love a set of replacement wiper arms. Have had one arm so sloppy it left the car somewhere near Palm Beach at a great rate of knots :oops: . The set I put on (by cannabilising the EK) are little better.
The splines seem to have a slight taper to them (could also be wear though they looked Ok to the eye). The tips measure 0.536", whilst the base of the splines measure 0.544".
briby
Post by briby »
Had a bit of luck, an Aussie company [TRUVISION] making parts that fit our cars. As you can see from the photos, they multi fit. In a pinch if your spindle is totally useless you could machine it down and fit the boss, but my drivers side i thought might be screwed but with the new arm on, almost as good as new. They also make wiper blades to suit bayonet style which i guess is OEM, i used my old wiper blade holder. Got mine from SpeedScreen in Campbellfield, Vic, other states ring TruVision for a stockist.
I don't think i need to do a how to, each new arm pack has a double ended arm, basically just cut off the hook to suit your crank and cut the other end to suit your length. The arm is held in the head with a plate and allen head screw, the same size as the wiper switch screw.
Wiper Arm.jpg (77.33 KiB) Viewed 1593 times
Wiper Arms.jpg (79.27 KiB) Viewed 1593 times
