Moderators: reidy , Blacky
Posts: 3687 Joined: Mon Feb 05, 2007 4:42 pm
Post
by Thommo » Fri Nov 23, 2007 8:28 pm
I cut mine on a lathe with a hacksaw, while it was spinning,
Then used an angle grinder the same way.
stinky
Posts: 906 Joined: Tue Oct 11, 2005 10:06 pm
Post
by stinky » Fri Nov 23, 2007 10:01 pm
If you are taking it through Regency, do not cut the bump stops as they require a minimum bump stop height. They are fairly generous with their bump stop clearance though, last time I checked -
Bump stop min height - 51mm
Bump stop clearance Front - 25mm, Rear 67mm
basic.green
Posts: 368 Joined: Wed Sep 19, 2007 2:31 pm
Post
by basic.green » Sat Nov 24, 2007 3:54 pm
Hi all. REGENCY not if i can help it. Thanks Stinky for the measurements i will do some measuring soon. do the stops just unbolt.
building the dream Rick
Post
by Thommo » Sat Nov 24, 2007 4:21 pm
The stops just pull out.
A little twisting may help.
stinky
Post
by stinky » Sat Nov 24, 2007 6:21 pm
A bit of detergent and water if they are really stubborn
basic.green
Post
by basic.green » Sat Nov 24, 2007 8:25 pm
Thanks for you help THOMMO and Stinky
