i just bought brand new kings spring that dropped car spot on 2inches and are $155 deliverd to queensland but think they come from melb or syd would have email adress somewhere let me know if you want it and i,ll hunt for it
Don't put any in at all, maybe you could get away with a couple of slinkys just to pass rego. Be nice and low then, and make more use of the bump stops.
2 and 3/4 that should of well and truly put the car on the bump stops
i'de say 11/2 would be ok depending on how low you want it
everybody that knows me says that's what i do ek61
just changed mine again today
i just pulled my front end off and my bumpstops were smashed to bits
im raising mine im over feeling every little bump in the road metal smashing metal cant be a good thing
***just cruise***
I have some cut springs at home you can have, not sure how low they are but you can try them out. If they are too low, measure them up against your stockies and cut a little less off.
PM or email if you want them.
Hi all. Thanks for your help with my ordeal Cut springs today took 11/2coils of. When i took it of the jack Man is it LOW. I looked at the bits i cut of and they had been cut before all thought you would not have geest it. How do i cut down the bump stops? If i can get it in and out of the driveway they will stay If not (Stinky)
best way i've found to cut down bump stops
remove the stop, cut about 1/3rd off and then use a grinder preferably bench grinder and grind it back to a peak and refit
i've found if you just cut it flat you get a more harsh bump by putting the peak back in it gives more of a cussion
