Small Block for EK Wagon
- WesternWagon
- State: WA
Re: Small Block for EK Wagon
Your on the money Harv, I have ordered a new stainless tank with a 3/8 outlet.
A new 3/8 stainless line will be going in.
Gazza
Gazza
Member : Holden Car Club WA.
:ASRF Member
:ASRF Member
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>WesternWagon wrote:Your on the money Harv, I have ordered a new stainless tank with a 3/8 outlet.
Gazza
I was afraid you would say that .......i new deep down 3/8 was the way to go ........but didnt want to go to all the hassle of changing the pickup i the tank ...........Fiingers
my ones with mild 308s have never had a fuel starve issue, a mate had a HR ute with a 12 second 1/4 308 running standard fuel lines no dramasHarv wrote:Fingers,
I reckon the standard FB/EK fuel lines are probably going to starve a V8 - undersized, often full of crap and bends/kinks/splits.... You can always check with a fuel pressure gauge with the vehicle under noise, but I'd reccomend some new 3/8" line.
Harv.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Mick wrote:my ones with mild 308s have never had a fuel starve issue, a mate had a HR ute with a 12 second 1/4 308 running standard fuel lines no dramasHarv wrote:Fingers,
Harv.
Mick your a gentleman ........
Hi Gazza,
i can send you a pic of my set up if you want, the lip has been trimmed around the fuel pump.
cheers
Dave
cheers
Dave
- WesternWagon
- State: WA
Still not happy with the steering set up, uni very close to the rear pipe.
Looking at moving the fire wall penetration down and to the right, will recess the firewall to clear the heads at the same time. (maybe grind the lip off to)
The older style CRS headers came up over the column, the new ones go forward? ( see pics of Greg’s Harv's & Matts)
Cheers Fingers & Matt for the advice. (Fingers will rer post the stencils)
Gazza
Harv's
Matts
Gregs (old set up)
Gazza
Harv's
Matts
Gregs (old set up)
:ASRF Member
:ASRF Member
I did this and are having a hard time keeping the steering column pointing straight at the driver. Will have to modifiy the hanger slightly but even then its gunna be slightly offcentre
looks similar
my steering column mounts lower down the fire wall
- WesternWagon
- State: WA
Quck update: Wagon blasted & primed, having the sills replaced
Found a few new minor rust spots
Gazza
Gazza
:ASRF Member
:ASRF Member
nice
its full steam ahead now!! will defiantly have to come check out your EKs when i move to Mandurah
Woody - UMX-282
FB EK Club WA
Foundation Member # 138
FB EK Club WA
g,day gazza ty here from mandurah spoke ealier about my ek just need your phone number to organise maybe to come visit.cheers mate!
hi Gazza.
I'm about to trial fit the engine to the front end (the same as yours but with a rear rack). The front of the sump hits the top of the crossmember like in your photo.
My engine mounts look the same as yours. Did you have the same problem with the tin sump? Whats your take on fixing this?
Hows the painting going..
Thanks Rick.
Thanks Rick.
Time for an update Gazza.................
......Fingers
and you too bill.....
WOW! That is all, just wow!
