Thanks Les, I could'nt find those ones, I must be going blind!!
I thought about just fitting a different bump rubber but now decided against having two types on the front.
I ended up swapping the bump stop of my old control arm to the new one so I can retain the original style stop.
Drilled out spot welds on both arms and fitted original bump stop to new control arm.
The attachment DSC00369.JPG is no longer available
The attachment DSC00368.JPG is no longer available
This work looks to be taxing enough for someone to have a sleep even while I'm grinding, drilling, and welding
- DSC00369.JPG (36.88 KiB) Viewed 940 times
