Engine Bays
insidemetal
Engine Bays
Post by insidemetal »
Im interested in and pics of original engine bays. If anyone has one of a 100% original, that'd be great. Ive got a couple that I think are close;
Post by mrs ratbox »
interesting pics and info tim :wink: i like seeing all the little nik naks that should be there :D
blue ute
Post by blue ute »
Love the pictures Tim
I'm hoping to get my ute back as to original as poss & the pictures have just explained a couple of things for me, but just a couple of questions - looks like you may've repainted the Bosch parts - what blue did you use, & although you don't have a remote oil filter do you know the colour of the (think it's Ryco) body.
blue ute
Post by blue ute »
Thanks - this is similar to the one I have - but in all photo's the body looks red & unfortunately my Bosch parts are painted black so can't eye match.
blue ute
Post by blue ute »
Tim mine is the same but dosen't have the 'whats its name thing' to the left of the bottom connection & not an AC lid - if I had a digital camera I could take a picture
ute-opia
Re: Engine Bays
Post by ute-opia »
hi guys,
i hope this thread from 2007 can be ressurected. I saw from the photos that one engine bay has a more modern air cleaner and one has a tear-drop shaped oil bath. I have a 61 EK with a tear-drop shaped oil bath. Are these both original to EK (i.e. was there a change-over period?) and also assume FBs had the tear-drop shaped oil bath as well?
also, it was confimed that the stubby metal pots sat on top of the master cylinders, not i've got 2 much taller metal pots? Does anyone know what the story is with these?
Is there anyone out there with original factory photos which could dispell some of these mysteries?
thanks, much appreciated
Ute-opia
WayneXG95
Re: Engine Bays
Post by WayneXG95 »
Yep but should be in another part of the forum I think. :?
bootlegger
Re: Engine Bays
Post by bootlegger »
I got one of these air cleaners New in the box. Now I know what it is. Thanks Tim
samprinci
Re:
Post by samprinci »
SunnyTim wrote:Hi
There were 2 types of battery leads for the EK. For all FB's and up to Jan 62 EK's this type of lead was fitted, from Jan 62 the spring clamp type seen through right up to Commodore was used. Don't worry it's not acid in the battery box, just oil from the air cleaner :wink:
Tim
Hey Tim!
u da man... I was going to post this question, then I discovered this tread. So I think u have answered my question... :D :D :D BUT!!!....
... Ive seen the earth straps used for the negative..see my pic???? was this a common thing with FBs. I've seen it used a bit??
Second question is, with EJ's were the spring clamp used for both - & + ???
thanks
Sam
www.fbekholdennsw.com
samprinci
Re: Engine Bays
Post by samprinci »
ok thanks Tim... so the EJ should have for both - & + leads the spring type. & my fb should have same type as pix from your ek..
mr bean
Re: Engine Bays
Post by mr bean »
Hey Tim
Can you still get that ribbed washer bottle hose, and can anyone tell me where I could purchase the thingy that screws into the manifold for the vacum line for the wipers as per your picture.
Cheers Andy
