Horn not working - EJ
samprinci
Post by samprinci »
G'day all.
got a bit of a problem with my horn in the EJ. hope some one can help? its not working...
Tested the actual horns & they definitely work. So I think its a wiring problem???
As u can c in pix, the wire just slid out of hole, should this be attached to something? in the manual, its the only thing thats not covered? if it should be attached & to what/where & how???
Sam
www.fbekholdennsw.com
Re: Horn not working - EJ
Sam - pop the wheel off and short out from the brass ring to the steering shaft - if the horn works then you have a problem at the wheel end.
If it doesnt work then start looking at your wiring. There should be power at the horn and the wire that runs to the brass ring is the earth wire.
samprinci
Post by samprinci »
Great, thanks a million blacky.. appreciate the response.
but??? what do u mean by "short out from the brass ring to the steering shaft" is that just a matter of earthing it to metal???
that wire that runs from the horn contacts, how does it attached to ring? it just slid out, is it supposed to clip into???
thanks again
Sam
yep , just stick a screwdriver on the brass ring and touch it to the steering shaft , the pin that slid out of your wheel is meant to be like that , it makes contact with the brass ring behind it .
samprinci
Post by samprinci »
ok great... I'll give it a go tonight.
mucho-gruchos mate
samprinci
Post by samprinci »
ok so i tried to remove steering wheel off.... Not much luck. Went to buy a steering wheel puller as the manual suggests, but the guy at Repo, funnly enough talked me out of it, said its reall reasy n u dont need it. followed his instructions on tapping it with my hand all around the ratious, but no luck..
So is there any little tricks??? to make things worse, On close inspection (see pix) steering wheel had a lot of crack, if Im pushing & pulling to with force from my hands, whats the chance of breaking the steering wheel????? & if u break it is it still possible to remove????
cracks - right
cracks - right
cracks - Left
cracks - Left
manual instruction
manual instruction
samprinci
Post by samprinci »
cracks - centre
Get a steering wheel puller - they cost bugger all and last forever.
I made mine on a minesite when I had nothing to do one day - took about an hour from memory..........
samprinci
Post by samprinci »
ok.. will do.
thanks again Blacky
:D :D :D
Steering wheel wont break Sam, they have are based on a steel frame.
Sam , if you arent going to use a puller, wind the nut up until its flush with the end of the shaft , jam your knees up under the wheel and push up with your legs then hit the shaft using a brass or copper drift and a lump hammer. This usually will get them off.
Cal
Post by Cal »
I actually broke a puller trying to get a steering wheel off a Centura years back. Finally got the wheel off, but cracked the nut in doing so
samprinci
Post by samprinci »
Devilrod wrote:Steering wheel wont break Sam, they have are based on a steel frame.
oh??? :oops: :oops: :oops:
Thanks DR.. I'll use a bit more force tonight.
Blacky... I'll give that a go. coz i went to buy a puller today but realised i left the wallet at home.. DOH!!!!!! :evil: :evil: :evil:
Peter... Hope I dont break mine.
All points take ladz. thanks again. I'll let u know how I go.
laterzzzz
Sam
:D :D :D
Cal wrote: Finally got the wheel off, but cracked the nut in doing so
Why did I cross my legs when I read that :shock: :shock: :shock: !
samprinci
Post by samprinci »
HA!!! too funny. I missed that one.
