Grey Motor Replacement Part List
Post original documentation here
FB1960
Post by FB1960 »
Holden Grey 138c.i.
Compiled a list of commonally replaced parts for the grey motor, list taken from as current a catologue as I could find.
Tridon auto parts
Ignition coil - TIC033
Flasher unit - HD13
Flasher unit non load sensitive - SD13
Electronic flasher - EP13
Wiper - complete blade set TBL12
Wiper refill metal rail (wide back) - MRW22 or MRW22-2
Wiper refill plastic (wide back) - TWR22 or TRW22-2
Oil pressure switch - TPS029
Radiator cap Standard - CN0430
Fuel cap locking - TFL206V
Fuel cap non-locking - TFNL206V
Thermostat - TT1-160
Thermostat high flow - TT2000-160
Thermostat Gasket - TTG29U
Water temperature sender (Gauge) - TTS068
Water temperature sender (Gauge) - TTS033
Oil cap – TOC540
CPC Auto parts
Radiator cap Std - 507-07
Radiator cap recovery - 536-07
Fuel cap locking - SL20
Fuel cap non-locking - 20X
Thermostat CPC 1-160
Thermostat Gasket - CPC34
Oil cap – OC64
Bosch
Plugs – WR10FC
Points – GB504
Rotor – GB73
Distributor cap – GB74
Condenser – GB61
Coil – SU12 or GT40
Fan belt - 11A0955
Leads
  • Set – B60021
    #1- B30SI
    #2 - B30SI
    #3 - B40SI
    #4 - B51SI
    #5 – B63SI
    #6 – B71SI
    Coil – B55CSI
NGK
Plugs – BP5S
Ryco
Air Filter A-24
Hope this is helpful
Marty
Going nowhere, getting there fast
Good stuff Marty, but could you add the Welch plug sizes, I couldn't find that info anywhere when doing my motor :? , Trev 8) .
great work Marty - thats gold and worth a sticky...
Stewart
FB MAD
Post by FB MAD »
Yep, that is VERY helpfull info there, saves a lot of time at the parts counter with the work experience kid looking up old parts books!!
FB1960
Post by FB1960 »
GB504 are listed as a re-release
because they were getting hard to find is the reason I went to electronic
http://www.bosch.com.au/content/languag ... _Ready.pdf
Page 10
Extinct Bosch Part numbers now available again!
GB504 Contact Set Holden EH - HK (Red Motor), VW
Sunnytim
They still list the rotor so you should be able to order it, American autos in Syndney list them as in stock if that helps you.
I'll see what I can find out on the welsh plugs
Marty
FB1960
Post by FB1960 »
added fan belt and air cleaner element #
Marty
strogger
Post by strogger »
138 Welsh plugs sizes
1inch 5/8 for the 3 on the manifold side
and 1inch 7/32 for the 2 under the side plate.
Anthony..
FB/EK Car Club of QLD
www.qldfbekholden.com
WesternWagon
Re: Grey Motor Replacement Part List
Post by WesternWagon »
Nice work
Member : Holden Car Club WA.
:ASRF Member
