I need a really simple explanation on the workings of rear brake cylinders.
Q1. When using Hr front disc boosted what cylinders do I use for the rear if the rear is not boosted?
Q2. When boosting the front disc and back drum what rear cylinders do I use?
Trev .
Trev wrote:I need a really simple explanation on the workings of rear brake cylinders.
Trev .
If the rear is not boosted then drum brake front rear cylinders can be used and if boosting front and rear the smaller bore disc front rear cylinders are used.
Asked the same question to Terry at Hydroboost about a year ago and he also said to use the HD/HR rear wheel cylinders applicable to a drum braked front end if using a front boosted only HR disc front end.
