I'm using a VB/VH salisbury and i have it sitting on the springs and trying to work out how to mount it correctly. I was thinking of using 50mm box tube to make the saddles but i need a way of housing the bush's ?
I would but the original diff went in 1985 and the HR diff is out on the floor next to it ready for its new owner . I think they used a pressed metal bush holder originally and i was thinking i could make up some out of 65-75mm box cut to shape .
Run a holesaw through the long face of some 75x50x5 RHS .
Use a holesaw the same diameter as the axle tubes.
Trim through the center of the hole.
If you offset the hole a bit you can lower it a bit as well.
To lower it more use a bit of 100x50x5 RHS instead.
Go slow with the holesaw using plenty of pressure and use plenty of lube or you will burn the holesaw out.
If you mark it out carefully you could use a grinder or an oxy.
wot179 wrote:Run a holesaw through the long face of some 75x50x5 RHS .
It depends on what you have at hand.
Great idea, i was thinking something like that would work , now my springs are 50mm wide so should i use 65mm or wider rhs ?
50 is spot on.
That way the vertical face of the saddle doesn't overhang the spring.
Drill the hole for the locating nut on top of the leafs neat and bolt them up without the rubber.
Use HQ -WB ute or van baseplates too.HR baseplates will bend if you are only using U bolts.
You will never bend HQ baseplates.
FCOV6 wrote:I'm using a VB/VH salisbury and i have it sitting on the springs and trying to work out how to mount it correctly. I was thinking of using 50mm box tube to make the saddles but i need a way of housing the bush's ?
does this diff fit or did u get it shortened thanks
Fits perfectly, i bought a set of BMW hotwire style rims but the offset is wrong so once i choose my wheels i will get standard commodore offset and they should be sweet.
I bought a set and they're good & strong. Much heavier gauge than the standard FB/EK ones. Only thing you have to do is enlarge the hole for the upper locating plate. Cheers
This is how it sits after dropping it back down on the ground, the front will drop a little more once i remove the 179 and drop in the buick V6. The BMW rims fit great at the front but just a little too wide for the rear without cutting out the lip or pumping the guards.
