HR wheel nuts
fxfjholden.com
HR wheel nuts
Post by fxfjholden.com »
OK I'm on a roll with questions today.
Changing my wheels on the EK to HT (running HR running gear) and currently I have 13 inch mags on them with mag wheel nuts.
Was wondering 2 things does anyone know what size the standard HR wheel nut are? and secondly I am after 20 of the fellas and was wondering does anyone have any?
Any help would be appreciated.
Jason
"From FJ to HZ, if you don't drive a HOLDEN you're better off DEAD"
fxfjholden forums - http://forums.fxfjholden.com
thropzed
Post by thropzed »
HR are the same as EK
Cheers Theo Z....................
FB/EK Car Club of QLD.
fxfjholden.com
thought as much but don't have any of them either.
Jason
If you change to HT rims you must use HT nuts, they have a different taper on them, Trev 8) .
You should be able to buy them new from just about any auto accessories shop or tyre joint.
newman
Taper???
Post by newman »
How much taper difference is there and does it matter??
I thought as long as they are 7/16 and the threads are o.k. :?
If the nut have a different taper they don't bed into the wheel correctly and come lose, it has happened to me but I caught it in time :roll: , Trev 8) .
