irs diff ???
stubby
irs diff ???
Post by stubby »
gday folks , ive got a statesman doner car for the ute and its got a irs diff . im wondering if i can shorten it like the normal diff.
stubby
Cant see why not - its easy enough to shorten a Jag diff....
stubby
Post by stubby »
gday blacky, yeah i remember the jag diff was all the rage when customiseing a car. id like to go this way but having a look under the stato the brakets look like alot of work to fit to the ek, but ill see when i strip it down. PS blacky i lost your mob number i called you awhile ago about the front bumper and front 1/4 windows im still keen on them if you still want to part with em
cheers. stubby
stubby
Blacky's mobile is the easiest to remember, you'll see when he gives it to you again :D
Yeah - its an easy one -0216746826585213756915676546949512358059198046125945252125157042651281546109120640823082606942692523808274015642094281282318754604296420182176142462072890867690290798028 :D
Or try 04 1960 61 62 .
EKjimmy
Post by EKjimmy »
you must have asked specifically for that phone number blacky! is that for real? lol fantastic
jimmy
Blacky wrote:Yeah - its an easy one -0216746826585213756915676546949512358059198046125945252125157042651281546109120640823082606942692523808274015642094281282318754604296420182176142462072890867690290798028 :D .
Thats the one I remember :wink:
FB MAD
Post by FB MAD »
No wonder I couldn't get you on the phone Blacky, I put a three instead of an eight on the 69th number there :roll:
fxfjholden.com
IRS Diff
Post by fxfjholden.com »
Ive got a VP IRS in my FJ panelvan. It fitted in without any modification to the IRS cradle. It allows us to run ABS brakes on it.
Be careful with the IRS in commodores as mine is a VP one the VS although the same size cradle didnt fit, (wheels stuck out at least another inch)
I have attached a pic.
Here is a pic of what the IRS looks like outside the car
The reason we put it in a van was the chassis. A sedan may require a little more work.
Jason
"From FJ to HZ, if you don't drive a HOLDEN you're better off DEAD"
fxfjholden forums - http://forums.fxfjholden.com
stubby
Post by stubby »
thanks blacky. with your fittment jason is the irs the same as the standard commodore diff with the long and short axle?
stubby
FCOV6
Post by FCOV6 »
stubby wrote:thanks blacky. with your fittment jason is the irs the same as the standard commodore diff with the long and short axle?
Looking at the photo i would say the pinion is off centre so i'd imagine that the half shafts are equal length ?
Craig
Post by Craig »
Glad Im not the only one :lol:
Better dead than red
EK, the VN of the 60s
Dr Terry
Post by Dr Terry »
Only the Commodores pre-VL had unequal length axles.
All the Borg Warner diffs use equal length.
Dr Terry
