spot weld drill bit ???
yogie
Post by yogie »
Hi guys, I am after a spot weld drill/drill bit?? Does anyone have picture of one, I've never seen one, and where I can buy one from. any help would be a great help... :D
Yogie , its easy to make one , all you do is get a normal drill bit , about 8mm , and grind the cutting edge back so you have a small point to start the drill with , then grind the cutting edge back so it cuts flat like a speedbit . Hard to explain but easy to do.
