still getting that f*%$ing vibration
Posted: Mon Oct 19, 2009 8:43 pm
by EKjimmy
new front engine mount, new front uni joint, rear uni joint is okay, suppose gearbox mounts could be a good idea too. what does everyone reckon? i think ill just take it to a mechanic and let him have the task of figuring it out, $*#@ it! lol
cheers, Jimmy
Posted: Mon Oct 19, 2009 8:47 pm
by (AUST)Mod
Tailshaft is out of balance?
Andrew
Posted: Mon Oct 19, 2009 9:58 pm
by EKjimmy
wouldnt rule it out. i suppose ill just have to go throught hte whole lot systematically. dammit
Posted: Tue Oct 20, 2009 3:35 pm
by FB MAD
Have you checked for slop in the rear gearbox extension housing bush??
Is rear uni joint seated properly in the yoke/pinion flange??
If you have a spare usable tailshaft whack it in and start the process of elimination.
Rear engine/gearbox mounts would probably have to be pretty bad to cause a vibration............ what sort of vibration is it?? ( yeah, I know , it's as hard to describe a vibration as it is to diagnose it :? :? :? )
Posted: Tue Oct 20, 2009 7:49 pm
by EKjimmy
yeah looks like its process of elimination, doesn't seem to be too much play from the gearbox. might start with harmonic balancer just to be sure...
Posted: Tue Oct 20, 2009 7:54 pm
by FB MAD
Yep sometimes when you are stumped as to the cause of a problem you have to start looking in other areas.
Not sure whether a crook harmonic would cause a real bad vibration but maybe a cause of some vibration?
Posted: Wed Oct 21, 2009 11:59 am
by Devilrod
Haven't lost any of the weights of a rim?
Posted: Wed Oct 21, 2009 1:40 pm
by EKjimmy
nah it settles down at higher speeds so its not wheel balancing
jimmy
Posted: Wed Oct 21, 2009 1:59 pm
by matchew
EKjimmy wrote:nah it settles down at higher speeds so its not wheel balancing
jimmy
i wouldnt totally rule it out because of that, i used to work at a tyre and wheel shop and sometimes at higher speed it was less noticble to a person that doesbt deal with it everyday
Posted: Wed Oct 21, 2009 3:03 pm
by FB MAD
:roll: Yep, depends on the tyre and amount of out-of-balance of the wheel but wheels can vibrate along all sorts of driving speeds and come and go at varying speeds as well.
Don't discount it, eliminate it.
Posted: Wed Oct 21, 2009 7:41 pm
by EKjimmy
thats twice this week i've overlooked a simple solution! loose belt, but on the upside it got everyone's brain ticking! lol
