new front engine mount, new front uni joint, rear uni joint is okay, suppose gearbox mounts could be a good idea too. what does everyone reckon? i think ill just take it to a mechanic and let him have the task of figuring it out, $*#@ it! lol
cheers, Jimmy
Have you checked for slop in the rear gearbox extension housing bush??
Is rear uni joint seated properly in the yoke/pinion flange??
If you have a spare usable tailshaft whack it in and start the process of elimination.
Rear engine/gearbox mounts would probably have to be pretty bad to cause a vibration............ what sort of vibration is it?? ( yeah, I know , it's as hard to describe a vibration as it is to diagnose it )
EKjimmy wrote:nah it settles down at higher speeds so its not wheel balancing
jimmy
i wouldnt totally rule it out because of that, i used to work at a tyre and wheel shop and sometimes at higher speed it was less noticble to a person that doesbt deal with it everyday
Yep, depends on the tyre and amount of out-of-balance of the wheel but wheels can vibrate along all sorts of driving speeds and come and go at varying speeds as well.
