HR lower ball joint replacement
reddo
Post by reddo »
Ok ..
The top ball joint on a HR can be replaced by simply undoing the 4 nuts and bolts and replacing the joint..
How do you replace the lowers??
They look like a press fit :roll:
Reddo
Yes they are press fitted, Trev 8) .
FB MAD
Post by FB MAD »
If you haven't got access to a hydraulic press Reddo, a bush repair would be to knock it in with a socket fit around the edge and a big hammer.
I just took mine to the mechanic and get them to press them out and press the new ones in, easy :D , Trev 8) .
reddo
Post by reddo »
Thanks guys.
Often wandered about them.
Too important / critical part of a car for me to attempt a home fix jobbie on it.
Will get a set of newys and give it to someone with the right gear to install them properly.
Reddo
DOLLER
Re: HR lower ball joint replacement
Post by DOLLER »
Are HQ BJs the same as HR??
The bloke at AutoBum may have given me the wrong ones as I cant even get them started.
vintageholden
Post by vintageholden »
hq and hr are the same....
bit of grease works well
vintageholden
Re:
reddo wrote:Thanks guys.
Reddo
getting them out is easy just smash them with a hammer...
putting them in still on the car isnt to bad..put them in from underneath
get a big socket close to the ball joint size.so you dont damage the nipple
a piece of tube a bit smaller on the top of the ball joint and bash it in...
done heaps oveer the years...
Brodie
Post by Brodie »
Every holden HD to WB including torana had the same ball joints.
And appparently from mid way through FE right through to WB and torries all used the same wheel bearings...
Holden certainly made use of what they had lol.
DOLLER
Post by DOLLER »
Yeah thats what I thought. I might have to press it in rather that use the knockometer!
does anyone know if this tool can be used on HR ball joints?
https://www.supercheapauto.com.au/p/too ... t=1&page=1
60Special
Post by 60Special »
Make sure you press them in squarely. It is possible to stretch or distort the hole in the wishbone and the ball joint will fit like a di@k in a shirtsleeve.
maybe you should just stick to your hat? :lol:
gpi wrote: Thu Sep 13, 2018 7:59 am does anyone know if this tool can be used on HR ball joints?
Yes, this tool can remove and install HR holden ball joints.
Post by Mick Jagger »
be careful i went with some local hd hr guys today and a lower ball joint failed
happenned to my brother many moons ago
get quality in that area with a split pin not a nylock nut that may get used more than once ..arrgghhh
to get out i hold by lower wishbone end and smash on gutter like im cutting a big tree
its got to come out square or youll be there all day
if its a loose fit 3 tack welds ....
kmawic
