hand brake cables
dave a
hand brake cables
Post by dave a »
just curious , what difference is there between manual and auto ,front and back hand brake cables? :? :?
BUILT NOT BOUGHT
FB MAD
Post by FB MAD »
Hmmmm....... I had one of my auto EK's up on the hoist today and was having a gander at the handbrake setup.The rear cable seemed to be slightly shorter than the manual ones but I'm sure someone will clarify this for you.
Post by mrs ratbox »
can't quite remember but i think the auto has a longer front cable, if not it's the other way round
reddo
Post by reddo »
Hi All
Just spotted this thread.
I have a handbrake cable question so rather than start another thread i figure i would just drop it in here. :roll:
When i finally get around to fitting the HR back end ( now blasted and painted . recod 3:55 waiting to be bolted in) under the panno , can i run the original FB/EK rear cable or do i need to scrounge up a HR cable??
Has anyone seen new cables offered up on ebay.. or is there someone who makes them.??
I often see front cables advertised ... but not rears.
Reddo
reddo wrote:Hi All
Reddo
i've made EJ/EH HD/HR cables work because i'm a tight arse, that place autcables i think is the name will make up what you want
FB MAD
Post by FB MAD »
Yep, I think autocables will do conversions if need be and if you tell them what brake/diff combo you are using they would most likely have it ready to post out to you.
I think their evilbay username is actually "autocables" or similar ??
reddo
Post by reddo »
Ahhhhh The power of the forum at work once again..
Thanks guys.
Reddo
they have their act together that Autocables mob - I rang them and said I need a handbrake cable for an FB ute with a LJ diff and he said no worries , I will post it out tomorrow. 8) No thinking or measuring necessary :lol: :lol: :lol:
Finny
Post by Finny »
I agree, Auto Cables do a good job. :D
I bought a cable off them.
Just tell them the Car model, Manual/Auto, Sedan/Wagon/Ute, rear end.
Mine was a EK Manual Wagon with a HR rear end.
They made it up to suit and posted it to me in Brisbane.
I had both the original EK hand brake cable and a HR one.
Probably could have got it to work, with a lot of re-engineering, but safety factor was a priority for me and having a proper one made to suit was prefered.
info@autocables.com.au or 03-94341410
Blacky wrote:they have their act together that Autocables mob - I rang them and said I need a handbrake cable for an FB ute with a LJ diff and he said no worries , I will post it out tomorrow. 8) No thinking or measuring necessary :lol: :lol: :lol:
Sure do! I got my handbrake cable (EJ diff ek front) and speedo cable (trimatic to EK speedo). Both times next day delivery :shock: :shock: 8) 8) 8)
(AUST)Mod
Post by (AUST)Mod »
If only KMAC Suspensions were like that
Sent them an email saying fb sedan with lj diff, please supply me with a rear sway bar.
Took my money, sent me a bar - to suit LJ torana.
Contacted them, asked to swap it, and he bit my head off saying i am a fool yada yada yada should have given more info etc?!
Andrew
Happy auto cables customer - got a front handbrake cable from them and it was perfect!
Stygian
Post by Stygian »
Andrew
Hey Andrew, I didn't have any problems with KMAC when they made new coil springs for me. Then again, I went in person to their Rockdale premises (a couple of 'burbs away from where I live). However, the guy who took my order kept repeatedly asking me if the springs were for an EK, which I kept saying "yes", "yes", "yes"... :lol:
Cheers, Andrew :)
