whistling noise under the bonnet
Wag62
Post by Wag62 »
Hi fellow FB EK lovers.
My problem is when I am driving EK 138 grey above 60kms p/h and take my foot off the accelerator I hear a whistling noise coming from under the bonnet, when I accelerate it disappears.
I have changed the solid vaccume line to the dizzy but hasn't fixed the whistle.
Any idea's would be appreciated.
Wag 62
NZ_EK
Post by NZ_EK »
I have been having the same problem in my jappa daily driver, I just tightened up the intake manifold and after a short drive it seems to have gone away, not sure if its the same sorta thing or not, hope this helps
Jas
careyman
Post by careyman »
U havent been through any road works lately have you?
once u get one of them lolypop guys under the grill there a bugger to get out :shock:
FB's=Friggin Bewdyful
Wag62
Post by Wag62 »
HA Ha haven't looked for the lolly pop man however he may be in the diff.
Intake manafold may be the next place to look as it only stared on a continuos 55 60mph run to the Gold coast.
Thanks for your suggestion NZ EK.
Also check that the nuts holding the carby to the manifold are tight.
A vacuum leak will cause a whistle.
Welcome to the forum also Wag62 :wink:
Jeff
blue ute
Re: whistling noise under the bonnet
Post by blue ute »
Wag62 wrote:My problem is when I am driving EK 138 grey above 60kms p/h and take my foot off the accelerator I hear a whistling noise coming from under the bonnet
Probably whistling because it doesn't know the words. :lol: :lol: :lol: :lol: :lol: :lol: :lol:
(AUST)Mod
Post by (AUST)Mod »
Blow off valve? Turbo spool? :lol: :lol:
Andrew
Lucy Blue
whistling wirring
Post by Lucy Blue »
Mable has that, but its the steel timing gear.
:lol:
I once had a piece of electrical tape on a tyre once, drove me mad till I found it.
intake or exaust manifolds I think?
If I could think of something witty I would put it here
Wag62
Post by Wag62 »
Thanks for all advise.
Found the base plate of the carby was cracked and a peice missing where one the lock down nuts go it have blown a peice of the gasket out.
Again thanks for the advise.
Wag 62
No worries Wag62 - thats what we are here for :D
