Idle adjustment via the wire link ?
Posted: Thu Jun 18, 2009 4:59 pm
by Finny
I have found that the my engine doesn't drop back to normal idle.
The idle screw is correct, but I need to manually pull the mechanism back to get the last bit.
Spring is already fairly strong.
It seems to be hitting underneath the manifold.
Is it normal just to bend the wire link to provide more space ?
It's the wire that's hitting, not the red bracket.
Do they normally sit against the bottom of the manifold ?
Posted: Fri Jun 19, 2009 11:50 am
by Sammy
unless im missing something it doesn't look like you have too many other options!
Posted: Fri Jun 19, 2009 5:59 pm
by Woodzy
Finny,
Looks to me, that the black spacer has lifted the carby up too high and the lower red bracket is fouling under the manifold preventing the the link to reach its rest possie.
I think!
But I know.. that you have to adjust, bend or modify the lower red bracket or the "wire", so it doesnt hit the underside of the manifold.
Free travel is a must.
Had a similar worry, with twin carb links stopping under the manifold preventing the carbs to idle.
cheers
Woodzy
Posted: Fri Jun 19, 2009 9:30 pm
by Finny
Thanks Woodzy.
I thought the Black spacer was standard
Haven't seen other to compare.
Just seemed strange that it's so close.
Will bend the wire which should be OK, but I expect I'll only get a small amount of movement.
Posted: Sun Jun 21, 2009 5:44 pm
by oldnek
I have to agree with Tim there Finny, Don't pull the phenolic spacer out, its there to prevent heat soak in the carby, caused by the big hot box where its bolted to the exhaust manifold.
(I know someone else posed the question, Re: spacers with Twin Carbs. (somewhere)??? Do you need them with Twin carbs. I said no, because there is minimal heat soak and there is no heat box on a twin manifold.
So I thought I'd clear this up before any contradictions were set.)
The throttle link on the carby appears bent to me, where it adjoins the spring link on the throttle lever.
And the spring should be attached to the firewall Just as Tim mentioned, and not run up to the carby. Going through the hole above the bolt adjuster.
Regards John
Posted: Tue Jun 23, 2009 10:41 pm
by Finny
Thanks for feedback.
Wasn't planning on taking out the black spacer.
I think the spring has been replaced with a weaker one.
I tried it in the other position but it was even less effective.
We can look at that on Friday to.
Posted: Wed Jun 24, 2009 3:49 pm
by roto
G'day Finny, Check for sagged engine mounts or for anything that is making the motor sit down lower than normal.
Hope this helps,
Regards roto.
