The idle screw is correct, but I need to manually pull the mechanism back to get the last bit.
Spring is already fairly strong.
It seems to be hitting underneath the manifold.
Is it normal just to bend the wire link to provide more space ?
It's the wire that's hitting, not the red bracket.
Do they normally sit against the bottom of the manifold ?
