tips and tricks
tips and tricks
hi all
thought it might be a nifty thing to have if we all contribute a couple of specifically FB-EK related tips that might make life easier when working on our rides.
ill start - if you want to remove your temperature sensor, use a spanner. if you use a socket, you will break the top off of it.
For most Grey Motor users out there as well as any engine that has a mechanical fuel pump,
If you run out of fuel and the fuel pump is lazy, remove the air filter and place the palm of your hand over the top of the carby sealing it tightly. Get someone to crank the engine and fuel will be drawn up there in 1/4 of the time.
John
John
minifb
- Contact:
LMFAO Trev..heheheheheheheTrev wrote:I'll give you a tip, GET OVER IT(AUST)Mod wrote:I got one -
If you want to improve the performance of your car, stick in a red motor!
Andrew, Trev
FB/EKForum member 123
Woofto Car Club Member No4
Woofto Car Club Member No4IF ITS NOT CHOPPED IT MAY ASWELL BE RESTORED
WEAR EYE PROTECTION
useing a wire wheel on an angle grinder today cleaning the thread on some head bolts the whole time thinking i should put my glasses on, last bolt a strand of wire flew off and hit me about 1cm above my eye went in a fair bit and blead like a bastard when removed, so can imagine would not have been fun if slightly lower
Clean hands..
Laundry powder cleans hands better than anything else..
Tablespoon of powder and a drizzle of water to make paste in palm of your hand.
Be aware, Gets hot and starts to burn once you mix with a little water, so scrub good and fast.
Rinse well..
Anthony.
Rinse well..
Anthony.
Anthony..
FB/EK Car Club of QLD
www.qldfbekholden.com
just a handful of things I have learnt along the way
Lowering the ass end
1. when installing lowering blocks put a jack under the leaves, that way if your lying near it you wont be scared shitless when it almost crushes your skull
2. check seatbelt bolts to see if they are rubbing on the tailshaft before you get a mate to come out and go over your brakes,
3. when cutting off U-Bolts make sure there isnt a leaky petrol tank above your head.
Engine choice
1. dont believe people when they say you can recondition a grey motor for about $500
2. Make sure you are prepared to buy a fuel pump, water pump, thermostat, thermostat housing and a flex plate when you buy a COMPLETE engine
Buying a Car
1. If you dont like the colour the car is, dont buy it
2. Buy something with a red motor if its gonna be a daily
General
1. Dont choose to recondition a motor 3 weeks before your P plates
2. Always use jack stands
3. Purchase a trolley jack and jack stands if u dnt already have them
4. Set out a clear plan of what you are going to do and stick to it!
5. DO THE BASICS FIRST, ENGINE & RUST then move on to customizing
Engine choice
Buying a Car
General
