I had two new flexible hoses made up previously, but I also needed one for the rear end (the HR one was too short and the EK ones had larger thread and didn't fit the rear end socket).
I installed the new flexible brake hoses onto the HR disc brake front end. The passenger side fitted and worked fine on both left and right lock (I have another issue there, but will add it separately)
The drivers side however is too short (need about 30mm extra)
Both hoses were the same length, and they both attach to "L" brackets that are welded into position.
So the question is, are they supposed to be different lengths, or is something else wrong ?
