I am considering putting in a manual gear box, I wanna be able to have some fun in it, squeak my tyres etc so Im looking for more power.
So yes I will have to take the engine out,
1.will the red sit on the same mounts as the grey?
2.will I be able to use the same accelerator linkages?
3.change the brake pedal,
4.add a clutch pedal,
5.can i take pedal assembly out of a torana or something?
6.cut a hole in the floor for the shifter,
7.or could I somehow put it in the column? (wanna keep it original looking)
8.can i use the same wiring etc?
9.can i still use the same drive shaft?
10.can i use craig's old recored grey radiator?
Andrew put a new engine in one of his rides, it was bigger and he just called up and said he wanted to change the engine number. I dont wanna go to the pits so I think I will just do that. If not just run it in there illegally and paint it grey or somethin
If someone could please answer those questions it'd be awesome!
cheers
Jay
