SOMEBODY MUST KNOW
ianthetiler
SOMEBODY MUST KNOW
Post by ianthetiler »
HI ME AGAIN I THINK BY READING LOTS OF THINGS ON THIS SITE THERE IS LOTS OF VERY INTELIGENT PEOPLE SO I AM HOPING SOME ONE CAN HELP WHAT KIND OF ENGINE MOUNTS CAN I USE TO FIT MY 253 TO MY FB VAN [FRONT CROSSMEMBER IS IN PLUS CHASSIS KIT AND THE RACK THANKS FOR YOUR TIME
IAN THE TILER
Is it a standard crossmember or has it been modified to suit a V8 ?
You will need a modified crossmember for sump clearance plus move the engine mounts on the crossmember or the motor will sit too far forward.
If you have bought a crossmember from CRS or V6 Conversions it should all have been done for you.
If all the mods have been made to the crossmember then a set of standard Holden ones should do the trick ?
