Neutral Safety Switch BYPASS
(AUST)Mod
Post by (AUST)Mod »
How can I bypass the neutral safety switch in my HG Prem? It has a Trimatic and wont start because it thinks it is in gear. I have discovered that the switch has broken bits of plastic falling out of it, so I think it is the culprit. It has 2 light purple wires going into it, and 1 light and 1 dark green wire also. The green and purple wires each have a separate plug. Can I short some of them together until I get a new switch?
Please help asap. I want to drive the car tonight :)
(AUST)Mod
Post by (AUST)Mod »
Fixed it. Needed to short out the purple wires. I think the green are for the reverse light switch.
Spot on . 8)
