Con rod nuts
Con rod nuts
Twas assemblin a grey motor yesterday and when it came to torquing the con rod nuts I stripped 2, so today on my travels I went to a nut n bolt joint and after about 10 mins of looking and a couple of questions I was told, " you won't get new ones, they don't make them" :shock: .
I can't believe this is true :roll: , so I went to an engine reco place and the bloke on the other side of the jump went out the back and took a couple off an old rod for me, life saver :D .
Has anyone herd of this, or have I been hornswaggled? :oops: , Trev 8) .
Hard to say, but they sure aren't making grey's no more are they Trev. Soooooo technically he's right, surely they are a standard size nut?
I know my old purple EK we had trouble getting big end bearings.
FB MAD
Post by FB MAD »
Sounds like the first joint you went to were too lazy to help you Trev.You didn't arrive there 5 minutes before closing time did ya?? :wink: :wink: :wink:
From memory they are a UNF thread but unsure as to what size.I'm sure any reputable engine shop should have had them.Only get them in high tensile grade ( not mild steel) and I'm sure they'd do the job as good as any original conrod nut would.
If you need anymore give me a yell,I've got a spare FX block here with genuine nuts on the conrods if you want some.
Thanks, Terry he said 11/32 UNF I think! Trev 8) .
FB MAD
Post by FB MAD »
Let me know if you need some Trev, I can rat some from the FX block I've got here if you need 'em.
The first shop may have been right if they are 11/32.It's probably not an often used size nowdays.
I'm rite now thanks Terry.
Just incase they are rite about the availabillity NOBODY THROW THESE OUT thanks, Trev 8) .
Craig
Post by Craig »
Trev get your torque wrench checked if you are stripping them
I snaped 3 rod bolts on a rebuild before I realised the wrench was out (I am a slow learner)
Better dead than red
EK, the VN of the 60s
FB MAD
Post by FB MAD »
I Never throw anything out Trev, thats why I've got so much shit in my shed and need a map to find my way around it!! :wink: :wink: :wink:
blue ute
Post by blue ute »
Me too FB MAD - have no trouble getting in my shed but need the navman to get out
Craig wrote:Trev get your torque wrench checked if you are stripping them
Craig, all the others torqued up no probs so it was just a couple of dodgy nuts, good thinking though :D , you might be able to be fooled 3 times but not 4 :lol: :wink: , Trev 8) .
blue ute
Post by blue ute »
Every mans nightmare :oops: :cry:
But could it not be a simple case of replacing nut & bolt - ARP for example
That was my next option :wink: .
4 Kids :roll: , I wish I had dodgy nuts :lol: , Trev 8) .
Craig
Post by Craig »
Trev wrote:That was my next option :wink: .
Trev wrote: :D , you might be able to be fooled 3 times but not 4 :lol: :wink: , Trev 8) .
Mate I've got 4 as well however they are all smart so not sure if the're mine maby I have been fooled 4 times
:lol: :lol: :lol:
