Steering wheel repair
What is the best method of filling the gaps in the cracks in a steering wheel so the filler doesn't fall out with movement.
I was going to replace the old wheel due to cracks, but might keep it if i can repair it or have it repaired.
Lynchpin
Lynchpin
where do you get kneed it from? repco and autobarn don't seem to stock it...just trying metal reinforced filler at the moment as i thought it'd give a tougher bond-but geez is it a prick to work with in small gaps!
Looks like i might have to clean it all out and start again
Nevermind! got some from good old bunnings warehouse. It's a pretty interesting product...according to Selleys you can use it to:
Repair small engine parts
Fill cracks in battery cases
and
Fabricate nuts and bolts
Sounds like a minitrucker's toolkit
But seriously, hopefully this stuff will give me a good result- nu metal or whatever i was using is s*%$
and
Re:
Don't use it on small or any engines It cracks and gives way after a while.EKjimmy wrote:Nevermind! got some from good old bunnings warehouse. It's a pretty interesting product...according to Selleys you can use it to:
Repair small engine parts![]()
Fill cracks in battery cases![]()
Re: Steering wheel repair
Personally I would use Devcon instead of "Kneed-It"
Its much, much tougher and is easier to force into small gaps.
I agree 100% with ash; only prob is it's much more expensive, and last time I bought some, was only available in a relatively large quantity...ash wrote:Personally I would use Devcon instead of "Kneed-It"
- State: WA
i repaired my steering wheel and gave it a fresh new coat of paint a while back now...with the full cycle of the seasons the cracks are back.
they appear at the join between the original s/wheel material and the new filler....looks like the bond has failed or the plastics expand/contract at different rates.
anyone else got the same results? anyone got a solution for this i can try when its time to repaint again...other than pearlcraft?
FB EK Club WA
Don't follow me, I'm lost too
