eh diif centre conversion
retro
Post by retro »
i want to run a better diff with my grey motor, i have an eh diff, and want to know whats required to fit it in..ie uni set up, tail shaft etc.
FB MAD
Post by FB MAD »
If you are only changing the diff centre to an EH one and not the complete drum to drum EH assembly then do this:-
Knock out rear grey motor uni joint and fit a red motor uni joint.Use red motor uni joint "U" bolts and nuts.
Pull out axles and the grey motor diff centre and fit EH centre ( will bolt straight in ) and refit axles.
Refill with diff oil and drive away, it's that simple. :D :D :D
What diff ratio is the EH one??..... 3.55 or 3.36 ??
strogger
Post by strogger »
I dont know if EH's had the 2 different splined axle types, but you need COURSE splines.. :wink:
A.
Anthony..
FB/EK Car Club of QLD
www.qldfbekholden.com
FB MAD
Post by FB MAD »
They only had the course splines in original EH centres.
Holden changed to fine splines around the HX Holden ?? or thereabouts.
dave68
Post by dave68 »
Terry U R a font of knowledge.
Whatever....:(
