which diff to use
workvan
which diff to use
Post by workvan »
i need some advise on which diff to use in my ute, im running a 186 with a traumatic, hr disc front end. what are my options?
low and slooow
Hr drum is the obvious choice, but I know where there is a volvo disc break rear, just need to get some spring hangers welded on, Trev 8).
Or EH/EJ bolts straight in, with a centre change in the EJ version. Also slave cylinders need to be changed to match the brake setup.
