what you need is a presure regulator,water seperator,,,about 50-100 dollars at most spray shops or tool shops,, wont stop water with out one and it will leave blisters in your paint,,draining the tank just stops rusting in the tank,,,,you can leave the drain open slightly just to help water dribble out,, but a seperator is a must
As said a water seperator - as part of pressure regulator or separate to is a must, either at the gun or the tank depending on what you buy, you often see them on eBay at a reasonable price.
The water comes from the tank into the pressure hose, a water seperator at a low point (say the tank) & lifting the line high would stop any water that did get past the separater.
Probably many ways & opinions on how to do it & what to use, it all depends on how serious you want to get.
