New spring hangers
New spring hangers
Just wondering if you can buy new (off the shelf) spring hangers for the conversion of a Volvo diff to fit an FB, or do you cut them off an old diff?
Trev 8) .
Whenever I do a diff change I press up some 3mm plate - you can make the sides higher and gusset them inside to act as a built in lowering block while you are at it....
