Rear Axle
- State: NSW
- Contact:
Rear Axle
G'day everyone,
How do I remove the rear axle? I'm assuming you have to do this to be able to remove the brake backing plate?
regards
Stewart
regards
Stewart
Stewart,
In addition to what Trev's said,
You'll will most likely need an axle puller to pull it out as well.It's basically a slide hammer that bolts to the axle wheel studs using the wheel nuts.
Or alternatively if you have an old rear wheel drum you could bolt it to the axle in the reversed manner that the wheel drum normally goes on and then whack the drum with a large hammer( making sure to not hit the brake components).
Use an old wheel drum however as this method will bend the wheel drum mounting face and stuff the wheel drum.
- State: NSW
- Contact:
brilliant! many thanks guys...
I have got all the nuts and bolts out...there is no way that I can get the axle out...looks like I need a puller or use Terrys suggestion...
Many thanks.
regards
Stewart
Many thanks.
regards
Stewart
Stew, Just use the drum as the slide hammer. Reverse the drum as Terry mentioned and screw the wheel nuts on a couple of threads and pull the drum hard towards you, keep compounding the action until the axle comes loose, make sure before you do it though you remove the half moon locating dics as Strogger mentioned.
Regards John
Regards John
mattymartin
- State: NSW
- Contact:
OK...decided to keep my dollars and use the drum suggestion...but instead of using a drum I used a spare rim...
It popped out with ease...after I tied the diff off to the pool fence...
next plan is to de-rust and repaint all the brake components...
do I need some sort of hi-temp paint...?
regards
Stewart
(first time newbie at this...if you havnt already guessed...
regards
Stewart
Doesn't matter how you got the axles out Stewart as long as it worked and didn't pull your pool fence down either
No paint expert here, but after derusting I'd clean all traces of oil/grease/dirt whatever from the parts to be painted and then spray a coat of High Temp Primer and then a couple of coats of High Temp Paint.
As brakes do get hot in use I would only use High Temp paint and not ordinary Enamel.
Stuart Bowyer
