I'm just gonna guess this is a problem
J
Post by J »
Filled full of red sh*%?
think this is gonna cause a problem? and solutions?
J...you don't use peanut butter for coolant...
Give the radiator a good flush out...
regards
Stewart
Post by mrs ratbox »
needs a flush, but it's hard to get rid of
J
Post by J »
half flush or full flush?
also where is the button :?
sillyness aside - can someone please write a step by step thing so I know how to do it properly?
FB MAD
Post by FB MAD »
Use an acid based cooling system cleaner.Follow instructions but leave it in overnight.Most are based on phosporic acid and is a fairly mild mix and can be safely left in overnight and drained next day ( after another 15 minute run).Flush system well after draining.If still rusty/oily give it another dose and same procedure.
Or better still, find a mob that can flush it professionally using a wynns flushing machine or similar.
Once it has been flushed, use a rust inhibitor in the system.
Had previous owners used rust inhibitor in the system then you wouldn't be in the situation you are now.
I'd pay the money and get it flushed properly. A mix of chemicals and high pressure plus if the place is any good they'll check everything while they are at it.
Finny
Post by Finny »
Get rid of rid all. It's in the radiator and the engine and the heater, and anything else that's attached. Professional or acid, then add the coolant. :D :D :D
Have you tried vegemite instead of peanut butter ? :shock: :shock:
