Speco floorshift for crashbox
Has anybody got a photo of a speco floorshift set up on a grey motor crash box? I have a complete shifter and linkages but I think it's from a later gearbox.
The shift mechanism doesn't have a model number on it so I guess only the linkages were different?
Craig
Re: Speco floorshift for crashbox
Nope Holden made 3 different 3 speeds all floor shifts are differentekv8ute wrote:Has anybody got a photo of a speco floorshift set up on a grey motor crash box? I have a complete shifter and linkages but I think it's from a later gearbox.
Better dead than red
EK, the VN of the 60s
Gday Markekv8ute wrote:Has anybody got a photo of a speco floorshift set up on a grey motor crash box?
I linked you to that thread because it had a pic of a speco floorshift set up on a grey motor crash box
to make it easy to compare what you have to a early set-up
Jeff
Hi Mark
It would be easier to make the crashbox shifter.
Your shifter has two linkages to shift two selectors on a synchro gearbox.
The stick operates either linkage by moving across from one to the other.
The non-synchro crashbox has one selector that selects all gears.
That one selector moves back & forth for 1st/reverse,
then slides out on a shaft to select 2nd & 3rd.
The stick pivots from the very bottom, which slides the selector in & out.
They are two differant actions altogether
requiring two differant shifters.
Have a look at the earlier link to the other thread,
they are easy to make.
Jeff
Jeff
