Dual throat weber
62cruiser
Dual throat weber
Post by 62cruiser »
hi everyone,
newby to this site/forum so i will give my brief history.
i have a 62 EK Alamo beige sedan with balanced, 20 thou oversize piston, ported/polished head, 30/70 cam.
i have had twin stroms on it and had problems with fueling up, i have a new dual downthroat weber that suites a 2.5 ltr.
1. is this a better option than stroms/ SU/ holley
2. if yes, are there any adaptors to fit weber to original manifold.
great site. :D
nic (62cruiser)
Webers are grouse carbs, but never seen an adaption for the original manifold, Trev 8)
FB MAD
Post by FB MAD »
I love Weber carbs.Easy to work on,go well, and have an excellent sound when full throttle!!
You'd probably be lucky to find a Weber to Grey adaptor but it shouldn't be hard to make one or have someone make one for you.
I made an adapter and put a 2 litre Cortina Weber carb on a 1.3 litre Corolla ( the missus shopping trolley ) years ago and it made a fair bit of a difference and it could be heard by my mates on full throttle from miles away :twisted: :twisted: :twisted: .
If the Weber is setup for a 2.5 litre engine then it would most likely go well on the warm grey as it is.
Do it!!
Terry.
paroharo
Post by paroharo »
any competent fitter & turner should be able to whip one up on a mill if you can supply the piece of metal (billet). 8)
62cruiser
Post by 62cruiser »
thanks guys, i will give it a go with the weber.
nic (62cruiser)
retro
Post by retro »
fyi i hope a hq style throttle pedal and set up is also on the cards.
