Stubb Axle Front
thropzed
Stubb Axle Front
Post by thropzed »
Hey Guys, I just had a thought about why I have to use a HR disc front end to get stubb axles for disc's, Why can't I put upper and lower control arms from a stubb axled front onto my standard front end????
Or has anyone used a jag front end to get power steering as well.???
I know that there will be an obvious answer but my brain is foggy at the moment. Looking forward to your replies and gesticulations.
Cheers Theo Z.............
FB/EK Car Club of QLD.
Theo z,
The HR front has a steel pin that bolts the top arm to the spring/shock tower and uses shims to adjust caster camber etc.
The EK has king pins and an ecentric bush to get the adjustments.
The Jag front is possible but not sure of the width or depth but it is a good idea!
You can make anything fit if you try although! :roll: :roll:
Post by mrs ratbox »
narrowed mitsu L300 with a rack adapted on
or most of the rack conversion guys do modified commodore racks in power steer or normal for the HR front
There is a 2 door FB over here with a Jag front end and a V6 Chev donk in it so the Jag front is doable
