Door Wiring
Malcolm
Door Wiring
Post by Malcolm »
Hi all,
Can anyone advise me on the best method of running wiring from the door pillar into the doors :?: :?: There isn't a lot of room between the door and the pillar when closed. I'm sure someone has come up with a fantastic idea for this problem.
Pickies would be good if possible :wink:
Malcolm W.
oldnek
Post by oldnek »
You can run them through the lower hinge on the door and on the outside of the hinge to body, I attched my speaker wires this way and looks pretty tidy. Just glued them onto the hige with Locktight 406.
Regards John
MAL,
Cant remember what car it was that I saw this but it had a rigid piece of curved tube that was fixed to the pillar and slid in and out of the door as it opened and closed.
The wires were inside the tube of coarse!
You may have to experiment before you drill any holes to get the motion right.
Post by mrs ratbox »
i've seen advertised somewhere a setup where they kind of plug/unplug in a terminal setup as you open/close the doors
Smooth customs
Post by Smooth customs »
An easy way to hide the wires is to weld a piece of tube to the back face, or bottom edge of one of the door hinges.
Check all clearances before hand for the best position. Sometimes a little filing of an edge is needed for clearance
I use this method on almost all the cars I have to do this on.
oldnek
Post by oldnek »
Another Idea I have just seen,
Contact switches on Toyota Tarago side doors, the 1 we just had in the shop had a 4 switch connection, camera is not here so I could not take a photo.
There little black connectors with flush brass contacts, held in with 2 screws.
Regards John
RedWhiteFB
Re: Door Wiring
Post by RedWhiteFB »
Malcolm,
I have asked about this on another thread, but just found this one and was wondering what you ended up doing with your door wiring?
Aaron
