hiding wires, step by step "FINISHED"...
mattymartin
Post by mattymartin »
ok team,
thanks to everyone who help me with all of my questions regarding hiding the wires in the engine bay... without your input none of this would have been possible
thankyou...
this is what i started with, some said not to bad. but i didnt want to see any wire, so i first opened up the bonnet, (still no cable) & started taking some before shots...
then wrote out a plan...
then just followed the plan... slowly.
started with finding a cosy spot for the next couple of weeks at
my Nan's places...
then disconnect the battery...
then disconnected the wiper motor...
stripped off ducting & tape & feed the just the wiper motor wires back through this little hard to find hole back inside into cabin...
then pulling it gently through & across, under the dash behind
the heater. then from the engine bay i drilled a hole using a 13mm drill
bit. before i did that i looked up behind the heater where the wiper motor is bolted to, to make sure i drilled in an ideal spot, safe & not visible. i then fitted a rubber grommet & feed the wires back through & reconnect...
next was the starter motor. i took the same steps as before, disconnect & strip back. (i always took photos before i disconnected anything, so i didn't have to rely on my memory where things went).
then once the wires were back insde the under & across the dash, i had to pull back the carpet & pull out this cardboard thing...(hopefully i can get a new one of these...
once i could see the metal i stated assessing were to drill the hole for the starter motor... then drilled using same drill bit & gommet size as before, feed the wires through & reconnected...
next on the list was the alternator, headlights, indicator & horn. first (i took photos before i disconnected anything, so i didn't have to rely on my memory where things went, again)...
then the usual steps stip off tape & or ducting & disconnected all of them. then frrd them through into the cabin & across & under the dash behind the heater... now this is the piont where i needed to extend the wires to reach there new home, inside the guards...
then i had to extend the wires... first, sniped & stripped off about 15mm off the end of each wire & joined them with the same colour wire... i then placed about 1.5 inches of heatshrink on to the old wire then twisted the bare wires together, then using the solder locked them into place. then i placed the heat shrink over the exposed wires & using a lighter i heated up the heatshrink & let it do its thing... (amazing stuff)
heatshrink on first then... twist
solder
heat-up heatshrint
then once i had my wires joined i need to drill a hole which would allow me to feed the wires into the guard. (be careful not to brake the drain tube, like i did)... i used the same drill bit as before but i used a grommet that had a slightly bigger opening, as there are about 7 wires that need to get through there... then jack the car up, took the wheel off for a better view. then i feed the wires through....
i then used some self adhesive plastic brackets to hold wires in place... (not sure how long they will stay there, but i 'm still looking for some thing better, that doest require drilling or screwing in to the car)...
i then had relocate the indicator, (which means disabling the indicator housing then i drilled a hole & placed grommet in the back wall just at the back of the indicator housing. feed the wire through then mounted housing back to car...
the headlights, horn & indicator where next & as i didnt want that connector thing screwed back into the car i used spade connectors & a bit of heatshrink to make them a bit more water resistant... then taped up and placed in conduc, the clips i've used are from jaycar, (there not meant for auto) they'll do till i get something better...
ok the right side done...
next was the highbeams... stripped the conduit & tape.
then i realized that it would reach inside without disconnecting the headlights/indicator, coil, temp dash lead, oil dash lead... (after i took some pic's & made notes where every thing went)
once the wires were inside i found out where would be a good place to drill a hole for the highbeam wires & then placed grommet & feed wires through & connected. (i always reconnected every thing ASAP)
then extended wires like i did on the other side previously, after measuring the lenght needed... (plus a bit more for theWHAT IF factor)
then drilled a hole CAREFULLY under the dash through to the guard, as i broke the drain tube on the other side... feed the wires through in to the guards & see where the wire need to go then place in conduit & clip to the car...
then i wasnt still that happy with the way the distributor area was looking... so i cleaned up the wires that were running to the coil...
before
after
then i was happy... for the moment.
over all i am very happy with the work that i carried out...
BUT...
none of wich would be possible without... (in no particular order) mephious, harko, devilrod, balcky, ekjay, thommo, smooth, ratbox, rosco, fb wannabe, fb mad, oldnek, craig, thropzed, blue ute, fb cruiser,
(AUST)Mod & parisian62... just to name a few
thanks
matty martin
go the wagons....
Tim
Post by Tim »
Great work Matty,
The right hand side looks great :)
Exellent details and pics, looking forward to the update :D
Cheers........Tim
ek61
Post by ek61 »
good work there 8)
the stick on plastic hook thingys under the guards looks like a good idea :D
***just cruise***
(AUST)Mod
Post by (AUST)Mod »
STICKY MATERIAL :)
ben
Post by ben »
Well done matty, wiring can be a pretty dounting task, but its looks like you have gone about it the right way. I have always taken the easy way out "if it aint broke dont touch it" when it comes to wiring, but i appreciate what you have achieved.
mattymartin
oooops, forgot...
thanks for the wake-up call guys, i'll finish the post today...
sunnytim, the car is undershelter at the moment & yes i know about the broken tube... BUT, i didn't know rares has them i pick some up ASAP...
thanks
matty martin
go the wagons....
Good stuff Matty, very well done.
No go get those drain tubes and save your carpet and floor!!! :lol: :lol: :lol:
Well done Matty :wink:
& well done all you forum helpers 8)
ekdave1962
ebay wire kits
Post by ekdave1962 »
hi all has anyone used those re wire kits on ebay .. come with neat fuse box and a bunch of wires ?
D
Matty Martin
Well done!
Just a couple of points that may help you out
1/ The hole you drilled for the wiring under the guard will leak if not sealed with silicon or something to that effect.
2/ Being a sparky I know these stick on clips don't last very long and usually fail when you dont want them to.
3/ You can use electrical type saddles that wrap around the cable then use a nut on the end of a guard bolt up high to secure them, this way no torn out cable from the wheel when the clips fail.
Hope this helps and a top effort I must say.
(AUST)Mod
Post by (AUST)Mod »
well deserving of sticky status :D a great tute
Dr Terry
Post by Dr Terry »
Hi Matty.
I just noticed your wiring at the coil, I don't think it's correct.
The +ve supply wire & the pink wire from the dissy should be connected to the +ve coil terminal. The radio supression capacitor also connects to this terminal.
The green wire from the dissy & your tacho wire should then both connect to the -ve coil terminal.
Dr Terry.
Post by mrs ratbox »
yor a champ matty :D it's good to see an enthoosyastic young bloke asking some questions and getting in and having a go :wink:
mattymartin
thanks guys...
wouldnt have been possible without forum member to guide me every step along the way...
dr terry, mate, i dont know what -ve & +ve is or which is which... is there some way of finding out if i have done it wrong... i just put the wires back where i found them...
which is where the auto electrician put them when he put in the elec' dizzy, that not to say he hasnt made a mistake....
he did have the car for just over 3 weeks....
thanks
matty martin
go the wagons....
i think you have it right matty as i'm pretty sure it won't run if they are the wrong way round, i could be wrong though but 95% sure
