Front & Rear Rust Repair under Window Seals
Macca's EK
Post by Macca's EK »
Hi guys,
Ive been searching the internet with no luck to date. Ive removed both windscreens so that I can paint the dash. I was expecting rust in the bottom corners of the window revels.
Does anyone make the outer rust repair sections for these areas?
The Front window sections are what I really need. The rear window rust shouldn't be a hard fix.
Thanks
Re: Front & Rear Rust Repair under Window Seals
I just cut the last front ones I had out of a wreck for a bloke over here mate, they are not super hard to find so hopefully someone on here can help you out - the rears are not that hard to make out of sheet
