trimatic crossmember
oldfb6
Post by oldfb6 »
G'day everyone, it looks as though i will be making a crossmember for my 202/trimatic conversion- CRS and Rare Spares don't do these crossmembers anymore, only i haven't made one before. I read on a previous entry that someone modified a HQ crossmember for their conversion, just wondering if anyone had any tips, ideas or photo's to help me in doing the conversion easily, cheers Craig
FB Cruiser
crossmember
Post by FB Cruiser »
G'day Craig, just saw your post and have to say that I did make one for my FB but I have put it to one side until I change the grey motor I got from you. Give me a call if you want to have a look at what I made. Im certain that this is just another small problem and with the help of eveyone can be easily fixed, Cheers PAT :)
TAYZ 58
Post by TAYZ 58 »
I have a rares one yet to put on, I will take a pic and get someone to post it maybe if that helps, you could maybe then fabricate one, now I think about it I reckon it would be pretty easy to make one I will have a good look tmw
Paul
oldfb6
Post by oldfb6 »
Thanks for the help, i will give you a call in the next few weeks Pat and organize a visit to check out your handiwork, cheers Craig
caz
Re: trimatic crossmember
Post by caz »
Interested in seeing those pics if you can get them on or send them to me by PM.
Yes! My Dream begins!
ek61
Post by ek61 »
i used a hq crossmember in my ek just cut it down to suit 8)
worked well the trans never fell out once :lol:
***just cruise***
J
Post by J »
WTF you can buy these things?
After all the hassle with mechanics and shit your saying I could have just bought one?
why dnt ppl tell me these things :cry:
Find my old EK thread, there will be some pics of mine in there.
Also there is a grey motor to trimatic conversion kit available which adapts the trimatic to mount to the original gbox mounts. That could work too.
Here's mine we made...
caz
Post by caz »
The 186 is longer then the grey, and I'm in NSW so they are fussy about what they pass for rego. I was told about the HQ crossmember, but was wondering if you need to weld plates on the side as well and bolt it on.
Mine is nearly the same as DR's except made with tube.
I have seen an extended chassis made out of RHS steal to go just past the end of the gearbox and a cross member bolted to that, very neat, Trev 8) .
caz
Post by caz »
All good, my super mechanic has designed and fitted a superb set up, will post some pics soon. Now on to the next bit...thanks guys for your tips! :D
Post by Mick Jagger »
Im in the process of making a crossmember for a 5 spd,did you plate the top DR,it looks a lot simpler than what I had in mind :)
kmawic
Yep, there's plates on top similar size to the underside and the bolts are tacked so the crossmember can be dropped without taking the carpet out.
mph
Post by mph »
Devil rod would you have any pics of your hand brake bracket set up on that cross member. Thanks
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Hi mph, I have wrecked out my ek I'd be happy to send you my tube n plate with hand brake welded to it cross member if you pay postage.
I'll put up a pic later when I get home.
