Master cylinder thread.
oz_ek
Post by oz_ek »
Gents,
Does anyone know the thread pitch of a PBR clutch & brake master cylinder reservoir ?
oz_ek
Re: Master cylinder thread.
Post by oz_ek »
I'm guessing this reservoir to master cylinder seal is NLA?
Reckon I got one in a kit recently. Also the rod grommet seal thing. Anyway it is just an o ring Phil. Don't know the thread size sorry. There was an earlier ABS one which was different but the PBR are later type. There appears to have been a change in size when they changed between the original tin types. One was a tall skinny tin and the other shorter and wider.
Tall skinny tin was EH , short fatter tins for our girls.
Dr Terry
Post by Dr Terry »
Sorry I don't know the thread pitch, but I can confirm that there are 2 different threads for both types of master cylinders (factory, PBR & other aftermarket types).
The early tin type (FE to early HD) had a rounded thread form which was smaller in diameter to the later cylinders. ABS & other companies did produce a plastic version of this smaller thread type. You occasionally see these at swap meets.
The later (plastic) reservoirs had a larger diameter, squarer ACME type thread as in your 1st photo.
Holden introduced the plastic reservoirs in June 1965 when disc brakes first became available in mid-HD. They needed a larger volume to cater for the piston travel of the front calipers.
To replace the rubber seal (pictured) I use a standard BS O-ring, BS215 for the smaller reservoir & BS217 for the larger one.
Dr Terry
Dr Terry
Post by Dr Terry »
Double post !!
As always great info Dr Terry
